As some of you might know, this is my trade. Even though I have changed professions i still do some work on weekends.
I have been trimming some historic racecars lately and thought u guys might like to see what goes into a basic race seat. These are new seats that are built to a weight so no extras that might weigh anything goes in. The seat rtimmed in the pic is a drivers seat and is heavier than a passenger seat. In the Historic class they have to have a passenger seat that looks the same, and they do, but havn't been made with the intention for any1 to sit in. Did I mention wieght? I remember 1 day when Matt was beaming ear to ear proclaming to have found 65grams hiding in an integral part of the engine.
Anyway, to start with you will will need an open space to work in with something on the work surface so the gelcoat/paint doesn't get scratched up.
then a shell that needs trimming
Some padding cut to the shape of the seat
Spray some contact glue on it
And in the shell
Just flop the foam in the shell...
...and trim it up.
I do a few of these so I have made some patterns for the fabric.
mark out and cut out the material
Sew the quilting in all the parts together.
Now you just need to glue both parts, flop it in the shell, secure all the edges and trim it all up neatly.
trim up the seat belt holes so the raw edges are neatly hidden.
and last of all you will need to make up a cusion that matches, and fit it of course so it wont slip out unterbrakes.
last of all it needs to be dropped off so the guys can put it in the #7 car. Yes the all have my interiors in them, and this is the last seat.... YAY! Job done.
https://www.sau.com.au/forums/topic/259394-recovering-race-seats/
GTR seats are a bit different though to fibreglass race seats as they are just a wire frame wrapped in foam then trimmed. would be much more $$$ and the hard bit is getting fabric to match the passenger seat and door trims etc. the only easy way to cure them is buy a generally less worn passenger seat and use the fabric off that. still not easy though.
I didnt intend for this to go this way but I have found a very good match for GTR seats. And as you say, new material does stand-out somewhat. The biggest headache with skyline seats in general is that the cover is glued on. Normaly there is a short sock on the inside with a spring/hardened wire insert that is clipped to another wire set into the foam. Gluing the cover on makes them a real pain in the botbot. And yes the price is much higher if not for the extra time spent but the AGRO tax that goes with it.
As a side note if you are serious about getting a seat covered, pm me. Might take a while though, it is realy only a hobby these days to help fund my own racing.
No the Astra does not have 1 of my race interiors in it. It was just in the way this morning. It's not often most of the RX2's are all together like that. Just made a good snapshot.
Stuart i've been meaning to come round get you to look at the Recaro's in my GTR, and generally say hi.
Sorry to hear about how the new manifold and throttles went, what you reckon manifold leak, or flow problem??
Rhys
  • 4 weeks later...
My god, look at all those RX2's :):cheers:
Good to see them put to good use, not just sik maccas cruisers or 9 second 13BT street sleepers
Ah,,,don't you all love a garage full of rotors. Come on,,,after a Skyline,,,what other tin-top would you own.
I'd like my Radicals seat done mate,,,pm me if you are interested. Yes it's full fibreglass.
Toyota's by the way are for poofs.
Neil.
depending on the materials you chose and embroidery, I shouldn't think it would be much if any more than the $300ish mark for a normal Vello seat. the wrap around seats will be abit more in materials and to be honest there a bit of a pain in the butt.
Niel, PM sent.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
