well that's not much good. you want some shorter than standard, not longer. I don't think 34 castor rods will give the desired result in a 32 and that's if they will even fit. but yeah, if they are longer than your stock ones then definitely don't use them. a longer rod will give you negative castor which is not what is desirable. you want to dial in some positive castor.
