Location Keysborough vic.
I dont have any pics atm, we all know what a roll cage looks like so i didnt take any.
Padding has a little rip on the b pillar hoop at the bottom, nothing some red tape wont fix.
rest is fine
I can get pics for any one interested though if nessacary.
  • 4 weeks later...
  • 5 weeks later...
  • 3 weeks later...
Sorry blokes i never check this website.
feel free to call me
0433 228 635
Sorry warlord. cbf posting.
If you organise a courier then up to you.
Btw still for sale.
make offer
Edited by anticeptik
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
