hey all.. recently put my built rb25/30 and rb25t gearbox into my cefiro..
im stuck at the gearbox mounts,
im wondering if anyone on hear is running an rb25 box in their cefiro and what they have used in the way of engine mounts??
i heard that a s13 ca18 gearbox crossmember can be used and makes it fit perfectly??
but cant confirm..
and no one in sa would happen to have a turbo cefiro rear section of tail shaft for sale???
haha
cheeers tom
https://www.sau.com.au/forums/topic/259590-rb25-box-in-cefiro/
but cant confirm..
haha
cheeers tom
Dunno about the Ceffie man, but it's what I did for the R32.
When you drop an RB20 manual box into an auto body, the crossmember holes are too far forward to use the rb25 manual crossmember.
The rb25 manual box will line up with the crossmember holes because the manual box is longer than the RB20 box and the same length as the RB20 auto box.
When fitting an RB20 manual box you need to use an S13 AUTO crossmember because they are a mirror image of the manual crossmember and will allow the holes to line up.
So in your case with the Ceffie, I cannot be sure as to which one you'll need. But if you run into the problem with one not lining up, the other should work.
Sorry man, I can't give you a definate answer, just another option in case you get stuck.
I thought it was when you dropped a 25 box into an AUTO 32, the Xmember bolts lined up perfectly but when dropping a 25 box into a MANUAL 32, you had to modify the Xmember as the holes in the chassis sit about 50mm too far forward.
I used some 25x5 flatbar welded to the 25 gearbox Xmember to suit the holes in the chassis.
Yo bro, that's what I said in the first sentence which refers to the use of an auto body. "When you drop an RB20 manual box into an auto body, the crossmember holes are too far forward to use the rb25 manual crossmember."
The second sentence, still with the auto body in mind - "The rb25 manual box will line up with the crossmember holes because the manual box is longer than the RB20 box and the same length as the RB20 auto box.
Just some wires crossed in communication.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
