I reckon a GTS-t, not the GTS-4 cause both have the same motor but it's a real b*tch to fix things when the 4WD plays up. Also try doing an oil change on the GTS-4 and it's a pain in the butt!!! I know cause the GTR's oil filter is in a real tight spot. You can't get the oil filter from underneath the car, but just barely from the top.
https://www.sau.com.au/forums/topic/2596-18k-to-spend/#findComment-47091
Think of it this way.....
How often is it a priority you need to get 100% traction?
If all you do is take cars traffic light to light, sure get the GTS4...
But remember the extra weight is not an advantage after the 60 foot mark.. more stress on brakes, heavier round the twisties...
Go GTS-T, RWD is ever so much fun :cool:
https://www.sau.com.au/forums/topic/2596-18k-to-spend/#findComment-47285
Originally posted by JiMiH
What kind of R32 can I get for 18 big ones?
I'm going to import to get maximum value for money.
A modded GTS-4 a good idea?
put it in long term property investment and get your self nice House...
and maybe, maybe down the track get your self nice girl and marry her then live happyly ever after.... :cool:
on other hand... FARK THAT! and BUY my R33 GTS-4!
cheers
Joe
https://www.sau.com.au/forums/topic/2596-18k-to-spend/#findComment-47298
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
