hey guys up for sale are a pair of work meisters in silver. they are in pretty good condition although the paint on one of the rims is starting to flake and one has a tad bit of gutter rash but otherwise still in pretty good condition. the stickers are there but kinda fading away. dish shines up pretty good as you can see in the picture.
tyres are bridgestone potenza re050a with about 50% tread with abit of camber wear.
was fitted on the front of my 32 gtst and fills up the guard pretty good.
selling these as a pair only because looking to upgrade to 9".
pick up in western suburbs only.
$500firm
hmmm.....i don't know for sure but i highly doubt it as they just clear the 4 pots with about less then a cm to spare on the 32.
if ur really interested come down and we'll try one on.
EDIT: just saw where ur from lolz. maybe some one can tell me if they do?
Edited by jakez88
have no idea but just off the top of my head maybe around $80. don't really want to ship interstate but if your willing to organise it then thats o.k for me.
bump need these gone and pms replied to!
just this pair is for sale guys! don't ask about the other pair because they aren't for sale! lol :banana:
Edited by jakez88
got a quote from pack send that from vic to qld should be around $120. happy to send them now as there is a pack send branch near my uni and can drop them off after skool. adelaide/nsw/act/tas should be much cheaper obviously.
bump bump bump bump it up.
i'm pretty firm on $500 guys. everyone knows how much these are a set so $500 for a pair i think is pretty cheap already. msg or call me on 0432454387 for a faster response.
Edited by jakez88
  • 1 month later...
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
