God_speed and myself have used the Digitech DC-1040 UHF CB before.
They've supplied very good clarity. Range is rated to be up to 8Km. That's not tested by us to the max tho'. My 2c
They'll both be used again at the 10th ANNIVERSARY R34 GT-R Celebration next month.
https://www.sau.com.au/forums/topic/260140-cbuhf-radios/#findComment-4477811
icom gear is great. I have an IC40s and honestly the difference beween 1W and 5W isn't as much as you might think, but it is great for when they ask you to repeat yourself you bump it up to high power and get heard. Remember that if the other guy has 500mW then you can't hear him, plus your antenna makes a difference if your radio has a tiny antenna it will have poor range for transmit AND receive.
as always buy shit and you end up buying twice. buy quality and enjoy using it.
https://www.sau.com.au/forums/topic/260140-cbuhf-radios/#findComment-4498555
Hehe Go for it! Quite clear eh? Good on cruises!
Funny how the cops say it's OK to use these but not a mobile ph. = INCONSISTENCY +
Really? So we can use handheld CB radios legally while driving? I thought all handhelds were illegal when driving????
https://www.sau.com.au/forums/topic/260140-cbuhf-radios/#findComment-4502800
The spec. on the FDC-460A has it at 1 or 5 watts which is pretty impressive considering the $$$$$.
I'd be interested to hear of comparisons to the Icom IC41s
Always found Icom gear outstanding.
I have only heard good things about Icom, but they are expensive. I am sure they are better quality than FDC though. That said, the 460A seems quite solid in construction and is built on a metal frame, unlike some cheapo plastic ones.
Disadvantages of the FD-460A are:
1. No supplier/distributor in Oz, so have to ship it back if it breaks down under warranty
2. Manual fails at English, although it's not that hard to figure it out
3. Car charger still needs desktop charging dock to be connected - can't plug directly into the radio unless you buy the battery replacement car adaptor, which means you have to change to your normal battery if you want to take it out of the car. :P
3. For some reason if you buy it with the 40 CB channels pre-programmed, you can't use CTCSS/DCS, unless you manually enter the frequency of that channel.
4. Antenna blows. As soon as I have time I'm going to Jaycar to get a replacement for a few bucks. I think it is an SMA-F port on the radio.
However, these are all relatively minor considerations when you consider it costs $90 delivered to your door, compared to the RRP of $160 for a 3W Jaycar one or $300 for a 5W Dick Smith one. I could buy three FD-460As for the whole family with all accessories and it would still be cheaper.
https://www.sau.com.au/forums/topic/260140-cbuhf-radios/#findComment-4502809
Yes I think for general applications, cruises etc, price outweighs that unit's minor disadvantages.
(IC41s is a touch under $400)
I had the old standard Uniden VHF on the yacht, mast mounted antenna. It simply didn't hear stuff that the Icom's had coming in clear as day with the same height antenna. Couldn't believe they supposedly have the same power.
Edited by grigor
https://www.sau.com.au/forums/topic/260140-cbuhf-radios/#findComment-4503165
Just came back from the member's GOR cruise.
Very impressed with the power and clarity of the FD-460A. Definitely no probs reaching everyone in the convoy with a cb. Many had lower power ones (0.5W, 1W) so they had some probs being heard.
Need to get a better antenna though. Neither Jaycar nor Dick Smith sell them, despite selling CBs. I think Timeplus on Sydney Rd, Brunswick is the only place that does in Melb???
https://www.sau.com.au/forums/topic/260140-cbuhf-radios/#findComment-4522591
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
