I am upgrading my brakes and will have a full set of R33 GTR brembo brakes and rotors for sale sometime next week. They are in good condition with plenty of life left on the rotors.
Price is $1800 which seems to be the going rate.
I may consider trading a set of standard Nissan GTR calipers and rotors, which I need for another project vehicle.
Drop me an email if interested and I will respond ASAP.
https://www.sau.com.au/forums/topic/260360-brembo-brakes/
Brembo's are located in western Sydney.
https://www.sau.com.au/forums/topic/260360-brembo-brakes/#findComment-4467722
Replied to PW's today so check your messages and get back to me.
Regards
It looks like taking a trade is going to be too hard so anybody interested in buying the brembo calipers and rotors outright is welcome to make a realistic offer.
Thanks
https://www.sau.com.au/forums/topic/260360-brembo-brakes/#findComment-4472147
Hi there, do you have any pictures? Will they require a rebuild or refurbish, etc, etc?
Were working fine and should be okay to run as is. Brembo's have a very simple piston seal setup and wouldn't be prone to damage unless you run them without dust boots, use crap brake fluid or don't change the fluid as recommended. The workshop manual says the seals and boots should be changed every five years for standard GTR calipers so I would think that Brembo's are similar. Obviously they don't last forever and will require maintenance at some point. I can't verify what life they have had before I purchased them, but I can say that I only drive my car every 3 to 4 weeks and not daily. They do show their age as the brembo stickers are dull and some of the paint is chipped so they would need a paint and new stickers if you're looking for show quality. The rotors are standard (not drilled or slotted) and have heaps of material left on them. I hope this helps and I will try to add some pic's tomorrow.
https://www.sau.com.au/forums/topic/260360-brembo-brakes/#findComment-4476687
you wouldnt be interested in a set of z32 brakes (calipers and rotors) by any chance ?
i'm pretty sure there the same as the standard r33 brake setup...let me know as i will be looking for a brake upgrade soon.
https://www.sau.com.au/forums/topic/260360-brembo-brakes/#findComment-4483432
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
