hey guys,
have my rims up for sale that are on my r34 gtt, there rays wheels but not too sure on model.
front are 17x8 with toyo tyres approx. 60% tread
rears are 17x9 with pirelli p-zero tyres that i just fitted the other week, done about 400kms on them.
the wheels itself have gutter marks on the outer edge.
you can contact me via pm or phone (can sms) on 0431537750
heres some piks.
price: $800ono
regards,
Baset.
Edited by WARLORD BAS
nice wheels mate had a set like these couple years back
bring back memories of 6 + 7 spokes love em
good luck with sale
thanks mate.
ok update on the rims. the 2 rear tyres are pretty low on tread now unfortunately :blink:
so price has been dropped and i will throw in a brand new CONTINENTAL SPORT CONTACT 234/45 R17 TYRE that is brand new and never fitter. worth abit.
NEW PRICE: $650
thanks mate.
NEW PRICE: $650
Wow Bas. Those tyres arent cheap!
