Hey guys,
I got my stock plenum polished up and when I put it back on again ( new gaskets ) I got this hissing noise coming from around the plenum when the throttle is open up.
Its definetely not a vacuum leak because the car is idling perfectly normal and its boosting fine
Any help would be greatly appreciated :P
Thanks
It can still be a vacuum leak, just a small one. You can try pressure test your intake manifold by blocking the pipe where it comes from the turbo's and then pumping up the intake manifold. If there is a leak it wlll be audiable at 2-3psi.
If everything is good you should be able to pump it up to 15psi and it should hold that pressure. Just be sure your plug doesnt blow out of the intake plumbing or it could launch quite a distance and cause some damage or injury.
what about the auxilary air control? was that taken off when polished? not sure how 34's go... but in 33's it is at the back of plenum (towards the firewall) and it lets in a small amount of air when idle (so the car doesnt stall when the throttle is closed) via a screw.... maybe you can just hear that because its clean now? or whats the condition of the gasket of it?
Its kinda hard to explain the problem so I will describe it the best I can
The hissing noise just appears when the throttles just open up , so if I hold the throttles open in any rpm it will NOT make the hissing noise
It sounds like "pssst" then goes away after that
The car is idling fine and boosting fine.
naut : The car is an R34 GTR its only running the factory boost sensor on the screen , you reckon I should check the vacuum hose ?
WYTSKY : I did taken out the AAC valve and put it back on with NEW gasket and I did NOT fiddle with the screw that controls the idle
Any more ideas / input ?? Im confused now :banana:
Thanks boys
By having the noise go away when you open the throttles it is confirming that it is a vacuum side leak. Meaning the leak is between the throttles and the cylinder head.
3 possabilities...
1. The gasket you relaced under the AAC valve.
2. Throttle shaft seals
3. throttle gaskets
Pressure test it and it will tell you which one it is.
VSPEC R33 : I have replaced all the six individual throttle gaskets , I did MAKE my own gasket for the AAC from gasket paper I have lying around
and which one is the Throttle Shaft seals ?
Thanks
Okay so I took the car to 2 garages and all of them sprayed brake kleen on the plenum + AAC and they couldnt seem to find any leak at all
ALTHOUGH the car is idling higher than before , its just above 1k rpm on idle
Anymore thoughts guys ??
Pressure test. Trust me you wont regret it. Youd be amased at how you can find the smallest leaks so easily, and as a reward your boost response will be better than you ever thought possible when its fixed.
tulalit where are you located mate???
QLD????
If so we have a span on gas machine that we can check of air leak's, vacuum leak's and boost, takes two Min's to hook up, or go to a shop that has one in your area.
Hey guys thanks for the replies :D
EFI Performance : I live in New Zealand , so I will take the car to ST Hitec on friday and see what he says ;)
Meanwhile I will replace the AAC gasket again see if it changes anything :)
Any feedbacks will be much appreciated :)
Since some of you mentioned the PCV valve, it occurred to me to mention the one way valve that is on the clutch vacuum booster. Ive seen them fail and then once the diaphram fails in the clutch booster it will actuall suck air from the clutch booster leak which will increase the idle speed.
Usually you can hear the leak inside the car if you just operate the clutch pedal when the car is idling. Its pitch will change as the diaphram moves.
Well I took the car to ST Hitec and he said I shouldnt worry about it and just leave it and he couldnt find any leak whatsoever
I might rip the plenum off one more time to replace it with metal gaskets this time
Thanks boys :)
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
