Don't make me have to teach you how to shift Mr whippy :P
going to try and put on teh super dragger tonight!
buzz me when your free or are shall i call the ambo for you? haha
Edited by Redsuns88
Yes i dont think you have quite mastered the art of "Ballz on chin" like funkymonkey did, but you never know.. sat night you may master it!!
lol haha zing
Edited by Redsuns88
ha i have no experience with balls on chinn - itll stay that way,
however
ive noticed since funkymonkey has been in melb your progress has been poor.. :P
Always can,
Cannot promise I will be sane most of the time..
supposedly i have a dry humor problem :S
Nismo boy where is jooor office!?..
i might make astrotristian rip a sik skid in his undies for u!
haha lol
Moggill road... Chapel Hill end :P
yeah that berry blast was good, apart from the masses of ice...
so much for fitting the dragger, f**kin 1 pce cat. :blink:
tar.
ps: qld section is poor.
I'm from Kenmore/Paddington although if your having a meet soon I'll only be able to rock up in my parts runner as my broad minded person it getting worked on at the mo :S
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
