well im down for baskins and robbins - prepared to give the girls one more chance, but funky wants pizza - so that'll be in kenmore or bardon..
How's about real food and ice cream after ya tight ass.
im sorry all i heard was;
"come over boys - hang out at josh's house, ill cook"
cheers buddy - im keen
I live in Bulimba..
There is some pretty epic cheese cake in the fridge at my work though. *looks out window* Redsuns 180sex has lost it's space saver :D
Whats your daily car?
and yes my car has lost its space savers.. its about to be changed into 2 space savers on the rear..
it will be a epic skid at the track or a epic skid in my undies when the rubber rips off
im sure we can go for pizza then ice cream.. but i nejoy washing my car and stuffzors.. lol but im just down with the crowd since im such a peoples person....
now..wheres my bobcat photos :S
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
