yeh man :)
OR we cud hit up some chinese in sunnybank :thumbsup:
I dont like committing hate crimes but if you really want to beat up people in sunnybank I'll come along...
BAHAHA!
hey it'll get us some free hondas..
u kno they got v-tec..
yo :thumbsup:
I SELL HOUSES
like a boss
SEAL DEALS
like a boss
IMPRESS CUSTOMERS
like a boss
I FLIRT WITH BITCHES
like a boss
LAST 90 SECONDS
like a boss
GET REJECTED
like a boss
I DRIVE A VOLVO
like a boss
I LIKE SAFETY
like a boss
I FLIRT WITH REDSUNS
like a boss
TAKE BALLS ON CHIN
like a boss
WISH I WAS A MAN NOT A BOY
like a boss
I SPOON WITH FUNKY
like a boss
I GIVE KILLER HEADJOBS
like a boss
TO MYSELF
like a boss
if you lads want, I can grab a family feast thing at nandos (st lucia) on my way back from work.
2x whole chickens and a large peri peri chips for about $35 or so.
Does that come with the Baskin robins outfit or nay?
you can suuccckkkkkkkkk diiickkkk for B&R outfit.
no nandos for you then?
ooohhh if you need your dick sucked Tas, I'd happily drop to my knees for you.
slurp slurp.
I'll even cup your balls gently.
please?
slurp slurp.
please?
goddamn you're a gay emo bogan from logan now?
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
