its not that different to yours... you just need more wide, more low and more epic fitment.
i don't give a rats arse if they have angel eyes or not... I need an HID that comes with a lens that's less than 3" diameter and is able to take a H4 dual beam.
so I can put it in this:
sorry, but epic FAIL
wonder how vicroads wud like them...:ermm:
vicroads will like what I let them like. pretty much all HID's are illegal anyways, cos they don't self level... so meh.
oh look out, its Dave, master of the universe and all that is R32s. Get back to me when you have one n driving condition sunshine.
wow, u woke up on the wrong side of tas's bed. its an opinion champ. no need to bite my head off :ermm: as for driving condition... one day.
tas' bed's in QLD and I'm in VIC. logic fail. lol.
if u took a more positive attitude on the subject i would be more inclined to suggest the right item for you..
eh?
ps: thanks for the heat wrap :ermm:
no worries, it was bought for you specifically, not found at the workshop as tas might have mentioned.
speakin of which, i gotta go back to the shop tomorrow and change those headlights over.
more people should be like that. you help me i help you. :ermm: even if you just found it its still kool, saves me cash on the proj.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
