i need indeed :D
see atleast i can sleep in my car - and then drive around wen i wake up,
you can only sleep in yours, then u gota wake up and fred flintstone that shit
You know that is quite true for the time being...
give it 3 weeks or so and u will be back to cupping my balls :D good ol times.. better start working out those thumbs and pinki's,... i expect you to 2hand that shit :D
Hey Dave can you do me a big favor!!
Can you take some measurements of your roof and cage for me?
1) Front of roof to where main centre hoop cage sits (taken from top off roof and centre)
2) Height of cage centre hoop from mounting feet
3) Distance of front hoops to roof taken from the top of the front hoop to the top of the roof and the distance of the top of the centre hoop and top of the roof.
I’m trying to determine if a non sunroof cage will physically fit into a sunroof R32 without hood lining (to allow room for extra height).
i call not funny funky
if you can sit thru this video and not laugh, then I'll happily retract that pic.
if you do laugh, you're a racist whitey.
tacio this pizzas last night were delicious XD
very delicious indeed
the occasion must have intensified the pizzas' taste :D
who was the veagan?
diff subjct.. wheres your oil cooler, what else have you ordered?
Im getting a day permit tomorrow so Im driving my car to get a paint job.. hopefully ready/ regoed by next friday!!
yeh boy.. drift day :thumbsup:
Tas - says:
shan man eating watermelon
tristannn - says:
yeh man
tristannn - says:
lame
tristannn - says:
didnt laugh
Tas - says:
i could so picture shan
tristannn says:
bahahahha
tristannn says:
"this is how u eat a zinger"
tristannn says:
bahhaah
Tas says:
ahah no
Tas says:
this is how u eat watermelon
Tas says:
hahaha
Tas -says:
his such a black man
Tas says:
lol
tristannn says:
he is
tristannn says:
bahahah
yo T-bond
yea i saw his oil cooler today rofl.. haha u could call it a front mount by the size of it.. rofl.
posting msn conversations is so 1998. fuckin amatures.
anywho. GTR bought, on its way to shipping yard. w00t.
u kno wat they say about guys with big oil coolers :P
oh yes.. oh yes indeed ;)
hope its not chinese!!!
dude im getting a trust 19 row with braided lines..
thats what you call empty wallet!
btw, bad news bout my car.. it sat on spray can paint for too long and rusted a fair bit.. needs HEAPS of work..
i was quoted 3 weeks.. :D
oh well.. do it once do it right
lol gay..
thats around the same time as mine.. turbz arrive around the 7th july supposedly
monday is to finish stuff and hunt for my Tein HA suspension!
that dyno day was pretty shiet..
i should organize one when i get my car running.! be sweet!
after i run in my clutch though :D
Edited by Redsuns88
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
