less chrome bro :)
boost cruising is that way ------->>>
lol boostcruising is :)
I just want some mad dish and this shit is all i can find, I would definitely like to keep the black with chrome lip look but they hard to come by.
Any suggestions on places to look instead of horrible insults.....lol jks
Yahoo Auctions - Japan.
I'll post the direct link to all 5 stud wheels 17's and 18's when I get home tonight
What sorta price range are you looking at? The Rays 57D looks quite good.
Dan: Agree with Tris.. Chromes are bad!
Tris: You'll probably like them since they come in fluoro yellow and orange!
Tas: They come in 4holes too!! But probably bad for resale.
http://www.rayswheels.co.jp/cgi-bin/cgi2/e...p;model=040_57D
Edited by Brandon
Mad dog, thanks man!
And yeah i agree chrome does suck
Price....about 2 - 3k
All 5stud in 18's
http://list1.auctions.yahoo.co.jp/jp/20842...=0jp&mode=1
"R34" keyworded 5stud in 18's
http://search1.auctions.yahoo.co.jp/jp/sea...=0jp&mode=1
All 5stud in 17's
"R34" keyworded 5stud in 17's
Just have a play with the search bar in the top left. Being Jap it doesnt under stand english the best, but you end up finding most things.
Oi another question....lol
I was just looking at spacers on ebay, You recon a pair of 25mm would do the trick for the rears?
http://cgi.ebay.com.au/NISSAN-WHEEL-HUB-SP...93%3A1|294%3A50
Edited by Danski
http://page2.auctions.yahoo.co.jp/jp/auction/b101594937
SHIT! If its easy buying there and these are genuine... I felt so cheated for buying the LMGT4s I have now!!! They even come with the dura nuts from rays...
Thats awesome thanks heaps bro
So if i find some that i like how that f*ck am i supposed to get them?
It's easy as buying shit off yahoo. You need to use a broker as you cant just bid if you dont have a Jap bank account however. There are loads of brokers, all charge around the same.
www.importmonster.com.au is one, there are a couple of small timer people on secret drift who are cheaper, but things may take longer as it's just a sideline business (Aussies living over there just earning some extra bucks).
Just do some re search and see who people have used.
Thats the start price and it currently has no bids.
Shipping is a killer on wheels. Mate picked up a set of uber rare offset Wantanbe's, was about $600. came to about 1000 - 1100 landed in Aus
Question has too many variables to answer correctly. Size? Offset? Tire choice? Not all tires are the same width, eg: some “225’s” are wider or more narrow then other 225’s.
Guards rolled? Flared? How low? What camber?
My rears are 18x11 (give or take) and I still was running an 8mm rear spacer… There was an easy 2mm more clearance, I could have run a 10mm spacer if I had longer wheel studs, even more if I got a narrower tire as my 225’s are wider than other 225’s.
What look are you trying to achieve? Like mine? Or more aggressive?
These are the only photos I have, they’re shit and I’m not going out side to take more as I’m lazy. As you can see the rims already sit a fair way out, when the car is off the ground and the camber is more like zero, they’re a good 1/2inch out past the guard line. I'm putting the rear outter lips on the front and having new rear outter lips made to make it aggressive
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
