There are no such thing as real and fake semi slick tires.
Essentially anything with a softer compound with less tread blocks then a “street” tire, creating a more flat area for contact on the road, that is/could be used in motor sports is a semi.. Obviously marketing loosely uses the term in brand marketing, however.
Khumo KU36, Federal 595 RS-R, are basically just very sticky street tyres with a few less grooves on them, but are marketed as 'semi slicks'
Compare that to the likes of Toyo R888, Bridgestone RE55, etc which are proper motorsport tyres. The grip levels and behaviour of the tyres are going to be quite different.
little update of what i've been up to all sunday / this arvo before seeing bruno... f**ked up shit.
welding done by yours truly....
gotta check up PCE on my fmic kit.
Sure they are. they are still a semi however.
That's like me saying I believe the Advan A048's to be more of a semi then the Toyo R888's as the "the grip levels and behaviour is different". Which is the case with the Toyo's and Advans..
Big jump in price, as I'm sure we all know.
I guess my main point is tyres designed for motorsport compared to tyres designed for the street. But whatever, its not worth arguing over.
If you run street tyres on the front and something like R888, Re55, A048 on the rear, it will be very unballanced and understeer like a dog when the rears warm up. I know, I tried it with RE55s on the rear one track day.
However, if by 'semi slicks' he means something like the federals or khumos, he can probably get away with it.
with josh? no it probably isnt..
*thinks back to baskins and robbins incident..
:blink:
Seeing I’ve been involved with competitive race cars, probably not.
I’m not sure why anyone would be running a street tire up front and a semi on the rear. You could get away with a semi on the front and a street on the rear, however again not sure why.
I personally am not a fan of mix and matching tires
hows your anti-baller offset treating you josh?
coming out thursday?
Pretty sure I hate narrow wheels.
I might come, depends how I feel. I've been going to bed at like 8:30pm haha
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
