yeah i will give it some WD love tomorrow, then finish bleeding the brakes and i can drive it again :happy:
booked in for an epic expensive wheel alignment on thursday (getting the rear control arms bent to adjust camber)
Who is doing it? I'm happy with my alignment.. But not. Would like to get it checked by a 2nd party.
Lets share a fetus.
i thought tristan and you were sharing a fetus already? or did you not plant your seed deep down enough?
lol so was I. but I was too busy postwhoring on misfits to register an on SAU lol.
You know your old school when you know what misfits was,
lerl @ all the newbie plebs in here
Well 3 corners are down, one to do in the morning and then just got to replace my rear cross member bushes and its ready to get an alignment :happy:
All went relatively smoothly apart from getting the front upper link arms to line up with the holes properly lol. Rear shock was a prick to get off but got there in the end.
Looks much better now although I think the rear could still come down 10mm. We'll see how it looks once the other side has been done and its had time to settle :mad:
Pics are coming tomorrow :D
Did you put a coke can at the bottom?
y u want to sell it josh?
I'll do you a straight swap for the XF :happy:
I only bought it for the wheels, then had a soft spot for it as it went pretty well with the turbo, but alas like all my cars I grew tired of it. TBH, I find slow (In comparison to my 490rwhp R32) and I want something else that’s more track ready, or something that could be far more easier
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
