is it just me... or is there something really really weird about this skyline...?
Skyline on Car Sales
*edit*
Hey Tristan. TOMMMY is up for sale too. I bet that hasn't been thrashed :P
Edited by Isola
Yes there is..
Ad says that its white.. funny looking white.
registration doesn't match up either.
$20 says the speedo is wound back like a bitch
Phew.. I didn't pick up on that. I was dead keen on that 32 up until you said that.. I'm out
*edit*
f**k some ppl are spoons.
Wat a waste of.....Oh wat eva it costs to post and add on carsales
TOMMMY also drives like an absolute f**kstain. I encountered him on Kingsford Smith Drive one night. Weaving in and out of the smallest gaps like it was a supercar challenge. f**king dickhead. Everyone was already doing 60. People like that really piss me off.
people who put spinners on skylines are rated the same as CA engines..
BIN TIME NUGGERS!
:P
and yeh - TOMMY is shocking on the roads,
hes almost merged into me!
..when i was in my 32!
and dont even get me started on the wheels
Tell me if the lines onto Pullenvale Rd are half decent. There was plently of smoke but these tires seem to smoke better then the marks they leave.
i do apologies i was greeted this morning with 2 lines. ahha :) ish i hurd it. when my cars done ill have to make sure they stay there :(
TAS GET YOUR SHIT DONE, im almost ready for roticery
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
