i do apologies i was greeted this morning with 2 lines. ahha :down: ish i hurd it. when my cars done ill have to make sure they stay there :)
TAS GET YOUR SHIT DONE, im almost ready for roticery
You doing R32 on the spit this weekend?
Lets go bed those new shocks in
Giving it a week or two then everything is getting tightened up then we'll hit up something on a saturday night :)
I'll give you that, seeing it's playing it safe :down:
dibs on co pilot :)
haha deal :)
Any luck moving the car? or finding another one lol
its only on here and sd.com.au
dont have to sell it and only would for the right price. Lots of things id like to buy.
this one's got tas.
-s14 +180sx.
get on it son.
also sport similar singlet as the dude in the background.
come out then African American still 1hr to go before we can buy some 2for 1 drinks
when its warmer!
who's got 2 for 1 drinks?
i want two for one drinks!!!
BP breh
:D
amazing
so are we organising a late night drink at BP hey?
:P
once your car and tacios car are on the road
ftw!
once my car is done you will only hear the faint blip of the throttle in the distance as i shift into Over Drift
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
