status on the SR boys?
had a good look under my car today,
Need new tie rod ends and pwr steer rack boots *guess i could add in spacers or rack spacers or somethng*, adj castors would be nice also need a hicas lock bar.
monday ill order a 3" high flow ceramic cat, finish off my exhaust system, tie rod ends, look at getting adj arms, suspension front and rear.. put in the new fmic...and take a look at my brakes. waiting on the sump goo i ordered before i put on my high volume sump lolz
oh yea i wirewheeled out the rust ontop of my strut tower thats right next to the quarter panel..
rofl now got a huge shiny whole :( ill weld it up and grind it back lol
sounds f**king awesome. hows status on the brake kits u were talking about?
very nice, make me proud. (fitment wise) !!!
f**k yeh man should fill out the gaurds nice, Old mate said they got an agressive offset (+22), might even need to get he front gaurds rolled :(
Edited by Danski
Wooooooooooo bought new wheels today - Rays CE28N 18x9.5
What yas think?
i <3 ce28s!
powder coat them flru orange or a dark green - will look sex on your white r34 :(:D
i <3 ce28s!
powder coat them flru orange or a dark green - will look sex on your white r34 :P:/
lol u <3 everything that moves :(
Woah! Nice. Someone's rich!
I was rich b4 I bought the wheels and fitted the rubber on em :P
I cant belive they impounded a little pewi 50 from a 5 y/o
We should go there in our cars and do circle work in the park.....well ill be there anyways :(
What yas think?
I hate you :( I want these on my car but couldn't afford em so got my XD9s instead :P
f**k yeh man should fill out the gaurds nice, Old mate said they got an agressive offset (+22), might even need to get he front gaurds rolled :/
Should look f**kin awesome :P Can't wait to see em
Should look f**kin awesome :/ Can't wait to see em
Yeah they a bit of a stretch as far as money goes but micko talked me into gettin em :P
Yeah they a bit of a stretch as far as money goes but micko talked me into gettin em :(
Cant expect less from a Rays. If you're thinking of those colours Tristan suggest you might be better of getting the Gramlight 57d. Very nice rims for drifters.
Nah man just keeping em the way they are, not a massive fan of the fluro colours.
And im def not a drifter :(
ive said it before and i'll say it again,
mick for prime minister
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
