have u got a dump / front? or u ordering gktech, feel free to borrow mine to see if itll line up, dont see why not.
I've got a dump, just need a front. Is urs a two piece or one piece dump/front. I might borrow it if its 2 piece, otherwise i'm just gonna take it somewhere and get a front made
Tristan bloody murdered that link, I think this is it: Click
thanks breh :thumbsup:
or go the bilstein/king combo. Get PCE to price it up for you or go ERD for the price of SS... I'll rather pay a lil more for SS.
http://www.sauqld.com/ipb/index.php?showtopic=823
The bilstein/king combo will be as good if not better than the Teins.
bilstein > tein
:thumbsup:
dusty car park at work provided a good photo opportunity to demonstrate how much tyre is wasted with 3deg rear camber:
Booked in for wednesday to get it set closer to 1.5deg :D
Nice lol must be killer on tyres
ps COLIN!
I FOUND YOUR DRIFT CAR
lllllliiiiiiiiinnnnnnnnnkkkkkkk
oooh yeeeh
gigity
Yeah. Hang on I need to go and piss on my money tree. Aparently it helps them grow :)
last set lasted 12 months... 6 months of that it was on axle stands :thumbsup:
6months!
you're doing it wrong,
learn to use the left foot, and boot it!
<3
lol I just noticed the awesome new ringpull design on my can of red bull
looks like this (I googled it as I'm too lazy to take a photo):
thats well wikkid, innit. RB POWA
excuse my n00b but wtf is BR?
ps just got back from the guy at archie who does epic wheel alignments,
nicest dude, did my alignment and flip my rears (due to epic cronic badass camberwear)
if anyone needs a wheel alignment or a good chat, shud defs hit him up
:D
however for ball cupping i cant talk PCE Perfomance up enough - they do a top job
thumbs, pinkies, soft/hard, you name it they'l do it
they even provided me with a mexican human seat while i waited outside for my turn, his name was taco or burito or something - lovely young chap
:D
:P
Hahahaha :D
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
