one of the mounts had to be modified - I don't have the tools or skillz to do it myself. I hate giving my car to a workshop...
You're not alone. A lot of the work requires proper tools which just cost too much. Unless you're doing it all the time, I couldnt justify buying them.
Go the front pipe and cat on today and only took 1hours to get the job done today but if I were to do it myself it would have cost 3x or 4x as much and probably a day's work. Shit thing is, the bloody Catco cat got the protection plate welded on the wrong side, so now the side thats facing the floor doesnt have anything.
Thanks Tas for fixing the front pipe and cat up for me today.
Nah mine's on top too but dont know if thats supposed to be the case. I thought thats for protection of the cat or something (which means it should be facing down)... -.-; Couldnt be bothered. The old cat has both side shielded.
Edited by Brandon
the heatshield? yours ended up at the bottom?
Mine is correct (heatshield at the top)... also a catco
from a total n00bs view i would say the heatshield should be facing the top (the car)
but i brandon i'd go see someone in the know who has experience, im sure someone here can recommend a joint, and get it checked out
If thats a heat shield and but for protection of the cat then yes I think it should be up. But the funny thing is the old 1 has it on both side. In any case, doesnt really matter. I'm happy to have everything up without any big dramas.
^^ and ask questions
you guys are wankers :cool:
catco are preweilded cats so when we alligned it for brandon the cat senor was on the opposite side.
so in order to get everything working had to flip the cat so it all neatly bolts up
thats why brandon i told you from the very beginning to let me get you a magna flow hi flow cat as the flanges can be weilded to suit
so thristian before u start to slander me think carefully :D
Top.
If its serving as a heat shield then yes its better to be on top (if there's only 1 side) but it'll be better to have them on both wouldnt it? But when I look at other stainless steel ones doesnt seem like they've got any (on the photos).
Edited by Brandon
well in that case it is right. So Tas, the only reason you had to:
was because it was upside down in the first place :cool:. The only thing you would have acheived by buying a not pre-welded cat would be having to do more work welding the flanges on.
There is no need to have a shield on the bottom, there is no sheild protecting the rest of the exhaust underneath so why would the cat need one?
There IS (on my car anyway) a heatshield ABOVE the entire exhuast protecting the floorpan from heating up. The cat gets an extra one probably because it is a bigger source of heat than the rest of the exhaust
to protect from speed bumps and what not from scratching and rupturing the actual ceramic insides?
or to protect anyone who works on the car when the cat is hot so it has a heat/bash plate on it
and simply no..
the cat senor wielded hole was on the different side matey..
ive got a better and cheaper idea. get a straight thru pipe !! no one will ever know, cats suck !!
how many times must i say it?:)
are you boys coming up this thursday?
so I was helping a mate drop a gearbox yesterday so he can put his new lightweight flywheel on. Got the gearbox off OK, but got to the flywheel bolts and his snap-on battery rattle gun wouldnt even budge them. After ruining one socket and then trying another one, we drove all the way back to my place (he lives miles fking northside) to pick up the ute and my compressor. It also couldn't undo the bolts! Eventually we got 5 of them off, but 1 was still stuck. So now he has no car to get to work today, lol.
I have pulled many a flywheel off before, none have been as much of a c*nt as this one.
On the bright side it meant I didn't have to help him get the gearbox back on :)
did ya try heating the bolts and just using a normal breaker bar?
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
