anyways wheres that place you was talking to me about making CAM's approved half cages?
You are better off and cheaper off using Nambour radaitors - They build both CAMS and FIA spec cage's. This is an FIA spec (full) in my mates car. a Half CAMS spec cage if you strip the car will not be too much
Bond Roll bars was who I was talking about yesterday -
http://www.skylinesaustralia.com/forums/Ro...on-t282289.html
Taz/Dave:
R32 ran better with the cleaner - Something is still blocking up and making the ECU dump a huge amount of fuel, I pretty much pop, crackel and throw endless flames, it looks good.. But clearly still something playing up.
Taz, can you get me a price on those two bearing, installed. Can you also get me a price on a Ryco Z387 fuel filter. I had this same problem with one of my other stock R32's when I ran the tank too low, cleaner, replace filter, cleaner replace filter. Came good in a week, but cost an arm and a leg :thumbsup:
what timing belt you got?? gates one??
if not then have to do a whole kit with a new timing belt at the same time..
did u want me to quote u for that?
Gates belt... You can buy each bearing on there own from Repco/Nissan AFAIK
Quote on Fuel filter price. Will buy two or three if price is better, but as Its not bulk, Id say not?
Quote on 2x bearings installed by you.
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
