BUGGA!
Went for the tune today and made 255awkw... I wonder whats the difference between rwkw and awkw... =(
But the car feels soooo much smoother now.
BUGGA!
It’s around a 15% driveline loss.
So say 255awkw + 15% loss (38kw) = 293rwkw = 392rwhp
Which is about right for a standard N1.
@super coach tristan: tried a new grip tonight and got 51 with a strike rate of ~210 :blink:
Also got about 2 dozen stumpings and catches behind the stumps and a few wickets bowling. Good night (y)
To break it down more, rwkw to flywheel kw is roughly x1.33
so, 293rwkw x 1.33 = 389FLYWHEEL KW
Both post's above are rough, everyone has different veiws on loss and conversion rates
Maybe all these while the 300kw I had in mind was rw not aw. But the fact that the car feels lighter/smoother really surprises me. 1st gear used to hit limiter at 60-70km/h now it goes up to 80+. Amazed.
A stock N1 will never make 300awkw, unless the dyno is happy, or you tell the tuner to input 300awkw on the graph lol.
Your car is very healthy and is on par - What else is done to it?
BUGGA!
Wooooo good shit
Ok, the list is as below
1) Trust Ti-R exhaust
2) HKS Front Pipe
3) Apexi Power FC
4) Apexi Boost Controller Kit
Thats all. Everything else is stock. 1.15bar I think (on the pfc hc). Cant get it to hold 1.2bar. No engine mods. Injectors are max at 90%.
Glad to hear the tune is good Brandon, who tuned it for you?
They must have lifted the rev limit a bit :blink:
Gavin Woods @ Autotech. Shit loads of GTRs... oh and 1 Tommy Kaira 32 (dont know real or not)
2) HKS Front Pipe
3) Apexi Power FC
Sort out why it's not holding more boost
- Get a better fuel pump
- Throw in some larger injectors
- Get a good set of cam gears
Spend more time on tuning and you will have a friggin quick car..
Your lack of boost.. They're N1's even 1.2bar is tame... and lack of fuel is why you only got 255awkw. IMHO, with the above and a very good tune you should get up around 280awkw, if you run more than 1.2bar..
If I'm ever gonna get it tuned again, I'll try Matt Spry.
Both Gavin and Matt gave me a good impression when I called comparing to the others.
He reckon its restriction. Or maybe injectors (he's not comfortable running higher than 90%). Or might be the boost controller (I've heard the kit doest hold boost very well after 20psi)
Don’t get me wrong, Gavin knows more about Nissans than most people – however to cut a VERY long story short, I bought a second hand Q45 throttle body from a wrecker, unknown to me at the time the wrecker swapped the TPS unit for a ca18 unit, which meant the car wasn’t tunable… My car was with Gavin for a full day and he couldn’t find what was wrong with it.
I took it to Matty and he found within 5 minutes that the TPS had been swapped over, we put the correct Q45 TPS in and had it tuned…
I know where I will continue to keep going back
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
    • Man, I miss having a phone that fits into my hand!
    • The speed this thing starts up is making me want to replace my old one. Though my old one immediately kicks into reverse camera as soon as reverse is engaged, it's clearly not part of the android system. For everything else though, starting up, connecting to hotspot, opening maps, starting music in spotify is easily a ~2 minute affair.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
