BUGGA!
Went for the tune today and made 255awkw... I wonder whats the difference between rwkw and awkw... =(
But the car feels soooo much smoother now.
BUGGA!
It’s around a 15% driveline loss.
So say 255awkw + 15% loss (38kw) = 293rwkw = 392rwhp
Which is about right for a standard N1.
@super coach tristan: tried a new grip tonight and got 51 with a strike rate of ~210 :blink:
Also got about 2 dozen stumpings and catches behind the stumps and a few wickets bowling. Good night (y)
To break it down more, rwkw to flywheel kw is roughly x1.33
so, 293rwkw x 1.33 = 389FLYWHEEL KW
Both post's above are rough, everyone has different veiws on loss and conversion rates
Maybe all these while the 300kw I had in mind was rw not aw. But the fact that the car feels lighter/smoother really surprises me. 1st gear used to hit limiter at 60-70km/h now it goes up to 80+. Amazed.
A stock N1 will never make 300awkw, unless the dyno is happy, or you tell the tuner to input 300awkw on the graph lol.
Your car is very healthy and is on par - What else is done to it?
BUGGA!
Wooooo good shit
Ok, the list is as below
1) Trust Ti-R exhaust
2) HKS Front Pipe
3) Apexi Power FC
4) Apexi Boost Controller Kit
Thats all. Everything else is stock. 1.15bar I think (on the pfc hc). Cant get it to hold 1.2bar. No engine mods. Injectors are max at 90%.
Glad to hear the tune is good Brandon, who tuned it for you?
They must have lifted the rev limit a bit :blink:
Gavin Woods @ Autotech. Shit loads of GTRs... oh and 1 Tommy Kaira 32 (dont know real or not)
2) HKS Front Pipe
3) Apexi Power FC
Sort out why it's not holding more boost
- Get a better fuel pump
- Throw in some larger injectors
- Get a good set of cam gears
Spend more time on tuning and you will have a friggin quick car..
Your lack of boost.. They're N1's even 1.2bar is tame... and lack of fuel is why you only got 255awkw. IMHO, with the above and a very good tune you should get up around 280awkw, if you run more than 1.2bar..
If I'm ever gonna get it tuned again, I'll try Matt Spry.
Both Gavin and Matt gave me a good impression when I called comparing to the others.
He reckon its restriction. Or maybe injectors (he's not comfortable running higher than 90%). Or might be the boost controller (I've heard the kit doest hold boost very well after 20psi)
Don’t get me wrong, Gavin knows more about Nissans than most people – however to cut a VERY long story short, I bought a second hand Q45 throttle body from a wrecker, unknown to me at the time the wrecker swapped the TPS unit for a ca18 unit, which meant the car wasn’t tunable… My car was with Gavin for a full day and he couldn’t find what was wrong with it.
I took it to Matty and he found within 5 minutes that the TPS had been swapped over, we put the correct Q45 TPS in and had it tuned…
I know where I will continue to keep going back
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
