the annoying thing is my clutch has started making a whirring/grinding noise now on start up/when cold. Bastard car knows when I have money I swear...
Its not slipping or anything yet so I'm not too worried. Dad reckons it could be the throwout? bearing. I don't know enough about clutches to comment. It makes the noise when the clutch is in so I'm assuming its not disengaging properly. The noise can be heard faintly in neutral when the clutch is out but normally goes away when the clutch is in. Now on start up the noise just gets louder.
Any ideas?
haha excuse thats a good one. Clutch will stay in the car until it absolutely, positively needs to be changed. Unless its free reving in 1st gear then its good enough lol.
@Colin: sounds like throwout bearing to me.
Wheres my invite bitch :)
Cool. Just trying to find out what it does.
oh and yeah wheres my invite John?
Google the Master of All Mortal Knowledge has provided a sufficient description of what a throwout bearing does. Sounds like that's my problem.
^^^ haha nice one mike.
may aswell do ya clutch colin, if ur doing the bearing. i hear the only way of buying a throwout bearing is with a nice new 5puk :)
ps: lick my dragon :(
An excuse to change the clutch!!!!!!!!!!
Hopefully that will stay at the bottom of my mod list although there's only suspension left.
fuel pump?
may aswell do ya clutch colin, if ur doing the bearing. i hear the only way of buying a throwout bearing is with a nice new 5puk :happy:
ps: lick my dragon :D
haha your such a liar. You can get throwout bearings in twin and triple kits as well.
ps: lick my dragon :mage:
new bearing costs about 10 bux :P but its a box out job so yeah might as well do the clutch while ur at it
Fairly sure I could get a throwout bearing for it, I'll have to find out :D . As I said I really don't want to change the clutch, its holding fine now and I wont be looking at a power increase for awhile. So I don't see the point in spending money on it when I don't need to.
colin isnt man enough to handle a triple plate
oooooo zing!
Just live with it then Colin. She'll be right.
sounds like the words of a true un-modifier....
shutup everyone, u can only get throw-outs in clutch kits. coln hitup tas and ask for flywheel to. :happy:
Wheres my invite bitch :happy:
This coming from the man who withheld the phone number?!
Nigga please... it's like 2 hours from your house!
but i'll ask and see if the two of you can come along... no promises though! and I don't know how much talent there'll be... but we'll see!
shutup everyone, u can only get throw-outs in clutch kits. coln hitup tas and ask for flywheel to. :D
haha...thanks buddy. I enjoy having my car in a rare, unique style. Normal. :happy:
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
