pics of it with the xd9s on it shan?
nah, just sittin upstairs in the shop for now lookin pretty. waitin on tas to get back to me on prices for Dmax 30mm flared fenders.
f**k yehhh, thatll b sexy as, i think tas is currently in talks with the jap dmax :)
woooooooooo
got some random mish mash of colours tho... i wanna get em powdercoated white. they don't make em in 10" +12 any more :)
Dave's underbody is almost as sexy as his underbody *wink wink*
hahah. thanks for all the help man. okay UPDATE bitchezzz thanks to some hard work from josh, we accomplished this finally today.
prepping for etch primer:
after etch:
and just managed to do a test run of my seam sealing skills, before calling it a day.
hope it don't rain tomorrow, start work on the engine bay :D plus ill post up a pick when i pickup my rims from getting christened with its first set of rubber.
Managed to get it to stay on its side did ya?
yeah that drum is holding it on its side, it was scary unbolting the front support to paint.
Looks good! Maybe you should take a full month off work to finish it!
a month, thats the total im aloud in a hole year. :down: have to wait till after chrissy i get 3 weeks.
Rains are comming Dave, starting to spit at my shack.
why did i just think of you eating corn and yelling out "ma ma the rains r here"
umm looks pretty scary outside, ive covered her all up. hope the plastic dont leak :D
and i just got a surprise from a nock on the door.
TADA !!!
anyone wanna buy a gtr for gtst front bar - CALLING TAS !!!
Becuase, deep down I am kinda bogan?
If Taz buy's that bar I will buy the type M bar ^_^
Saves me painting my black type M one.
John, PM me your mobile number so I can make the promised phone call tomorrow night
aiight... but if you throw off my :( rhythm... so help me... :D
Edited by Isola
what front bar are u usin dave? or did u buy that gtr shell?
gtr for gtst. havent looked at the shell, has come at the wrong time. ill probably ring the dude end of year see if hes till go it.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
