Hey anyone's been to willowbank can offer some sorta advise?
Whats involved if you're a first timer? They're having the test and tune event on Saturday for this month (WEEKEND!) and I'm pretty keen on going for 1. They've listed 40bucks as the entry but does that include the run? From what i understand, all you need is to rock up with approved helmet, long pant/shirt, cover shoe and sock.
check out boost - they'll probs have some info in it mate
Sup daawwg
I dont mind the 180's....they just hard to appreciate when you own something as sexy as a skyline hehe
they are YUMMEH!
Pretty much :thumbsup:
*kabab slap*
be serious now Tristan. They look distinctly average from behind.
i guess you're going to have get used to seeing the back of my 180 - u might as well let it grow on you :thumbsup:
Righto dudemans ima hit it, gotta plane to catch so I can come join civilization again.
Catchyas later woooooooooooooooooooooooooo
"dudemans"?
errrr??? :thumbsup:
grow on me like moss on a boulder or like a tumor in my nutsack?
WHORES! you sicken me.
nav_m.gif Today's Top 20 Posters Member Joined Total Member Posts Posts Today % of today's posts
Danski 2nd May, 2009 561 43 3.26%
astrotristan2 2nd August, 2009 390 25 1.90%
Nismo_Boy 31st May, 2002 17,204 17 1.29%
lol!
top 3 posters of the day so far hahah
Edited by astrotristan2
Yeah pretty much. Price does include runs. Be prepared to spend a long time in line ups, especially for the saturday ones.
yeh doesnt boost do tuesday or wednesday night ones? every week?
check out boost brandon :thumbsup:
f**ktard
No.
Willowbank do midweek ones Boost has nothing to do with it
should hit up a test n tune one time during the week. would like to know what my car would run. im guessing mid 13s but would be fun
A mate of mine had a near stock one, full pipes, cut up air box. Was running into the 12's. But his GTR went through roughly 3 gear box's...
Your GTR told me it wants to see some hill action, with Josh rollin Navman
Colin: Sounds like a plan!
Someone organize something and we can all go together! If its weekdays night I dont mind as well So long as its outside office hour.
Martin: Yea I would have thought so due to it being a weekend.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
