Hey anyone's been to willowbank can offer some sorta advise?
Whats involved if you're a first timer? They're having the test and tune event on Saturday for this month (WEEKEND!) and I'm pretty keen on going for 1. They've listed 40bucks as the entry but does that include the run? From what i understand, all you need is to rock up with approved helmet, long pant/shirt, cover shoe and sock.
check out boost - they'll probs have some info in it mate
Sup daawwg
I dont mind the 180's....they just hard to appreciate when you own something as sexy as a skyline hehe
they are YUMMEH!
Pretty much :thumbsup:
*kabab slap*
be serious now Tristan. They look distinctly average from behind.
i guess you're going to have get used to seeing the back of my 180 - u might as well let it grow on you :thumbsup:
Righto dudemans ima hit it, gotta plane to catch so I can come join civilization again.
Catchyas later woooooooooooooooooooooooooo
"dudemans"?
errrr??? :thumbsup:
grow on me like moss on a boulder or like a tumor in my nutsack?
WHORES! you sicken me.
nav_m.gif Today's Top 20 Posters Member Joined Total Member Posts Posts Today % of today's posts
Danski 2nd May, 2009 561 43 3.26%
astrotristan2 2nd August, 2009 390 25 1.90%
Nismo_Boy 31st May, 2002 17,204 17 1.29%
lol!
top 3 posters of the day so far hahah
Edited by astrotristan2
Yeah pretty much. Price does include runs. Be prepared to spend a long time in line ups, especially for the saturday ones.
yeh doesnt boost do tuesday or wednesday night ones? every week?
check out boost brandon :thumbsup:
f**ktard
No.
Willowbank do midweek ones Boost has nothing to do with it
should hit up a test n tune one time during the week. would like to know what my car would run. im guessing mid 13s but would be fun
A mate of mine had a near stock one, full pipes, cut up air box. Was running into the 12's. But his GTR went through roughly 3 gear box's...
Your GTR told me it wants to see some hill action, with Josh rollin Navman
Colin: Sounds like a plan!
Someone organize something and we can all go together! If its weekdays night I dont mind as well So long as its outside office hour.
Martin: Yea I would have thought so due to it being a weekend.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
