lol i guess you get what you pay for. Spose i could grab that shell and a wrecked donor car and transfer all the shit over. buy daves rb20 n box and away we go.
Buy mine, it runs. Sometimes.
GTFO!
blasphamy brandon! :)
colours are the fluro ones u saw in the option mag..
PCE is the way of the future..regardless of what car you have....no one could ever doubt the real quality and honesty of the work they produce there.. Astrotristian is my witness
Thristian: Bought 11ty billion T25*SR* T3*RB* turbo to manifold gaskets today.. much much better quality then i expected :D
f**k yeh man sounds gooood :)
i trust progress is going well?
you have a budget like Dave..
tehehe ;)
well that multi quote wasnt as epic as i thought it wud be hahaha :)
GTFO!
tehehe :(
Yeah Ive seen bigger ;)
Status Report for 8/9/09
Arrived at work at 6:15am
Made Coffee at 6:20am
Checked bbc.co.uk for any football news 6:20 - 6:40am
Surf SAU 6:40 - 8:30
Started actually working 8:50am
Get ready for subcontractor meeting 8:50 - 9:30am
Subcontractor Meeting 10:00 - 11:00am
Harass steel fixer for Quality Assurance sign offs 11:00 - 11:20am
Breakfast, Smoko & Lunch combined 11:30 - 12:30
Heart attack from eating full roast chicken from Woolworths 12:30 -13:00
More Surfing of SAU 13:00 - 13:30
Go on site and point at stuff 13:30 - 14:00
More Surfing of SAU 14:00 - 15:00
Do some actual work 15:00 - 16:00
Currently surfing SAU again.
CBF working today tbh.
Maybe you two (tas and tristian) should have 1 of those meter at the signature too!
That way we might have an endless cupping session for BnR
any recommendations where I can get a roof cut done? need to get rid of the sunroof as I can't fit in with a helmet
got a quote from Cameron's body works for 2k plus parts to get it done.
i can nearly find a complied shell for that money and just swap everything over..
hahahha yeeh we almost should :/
mate hit up nismo boy - he was looking into getting rid of his sunroof in his dirty 2
Been wanting to do the same thing:
http://www.skylinesaustralia.com/forums/Ca...-S-t273284.html
Also went and spoke to a shop in Underwood that do a few race cars/drift cars (they did the body work on the Option1 Silver 350z). Without sitting down at working out each cost, they said around $1000 to weld in a pannel.
I have seen roof cuts on ebay for as little as $150. Cut at the pillars, so easy to match and cut, then re weld. People are put off, but I don't know why - People take the roof off cars for SERIOUS roll cage building, it's not different - Your just replacing it with another one.
IMHO if anything putting a sunroof in a non sunroof car makes a car weaker then welding in a non sunroof, roof.
oh and yeah putting in a sunroof in a non sunroof car would weaken it big time. Especially if you don't do any additional bracing. As long as its all welded properly then there is no reason it won't be as strong as before.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
