Whats the difference? I always thought airbox are something you used to cover the pod filters which sorta affect flow but will keep the cops away. Or are the pod filters a replacement of airbox...?
Standard airbox's are black plastic things which have a panel filter inside.
ARC airbox's which Nismoman is talking about are alloy and bigger capacity and have an arc panel filter inside.
airboxes dont flow anyless then a pod filter really unless you have the air flow blocked off, but then your a nob.
People put boxes around pods to premote cooler air intake, so blocking off the engine back from the air filter...works a treat.
oh and maybe get your injectors cleaned, maybe that will help.
I am still running stock rb25 injectors for 280rwkw.
Edit: But I do have a fuel reg, and big fuel pump.
Yea I already know that. In fact so long as you've got the money, everything is easy. I dont think you'll be saying that if you've gotta pay 3k a month for homeloan.
You can tell me to bugger off, but out of interest who are you paying $750pw to and what are the loan terms and how much was it? (PM)
That’s a pretty serious repayment… (currently wearing his Real Estate agent hat). One of my old brokers did some magic things with numbers, but not everyone is suitable to refinance..
whores lol.
Agree with pretty much everything Nismo has said lol. Making power with a gtr is easy but it costs money so man up and buy the gear lol.
You man up and buy some gear :blush:
You've got PM. But basically 3k is including extra repayment and I like to have 3 months salary in the bank just for emergency. So as much as I like to spend those money, I wouldnt.
Very nice. Yea just got it tuned last week so I'll probably fault find and see if I can find out where is restricting the boost.
Would love to earn 3k a month in the first place :blush: But I get ya, more important things than the car to spend money on :)
You man up and buy some gear :(
I'm a pussy. I will gladly have pinkies raised at me. But everything I earn gets put into the car, I just don't earn enough to buy anything really cool :blink:
You do ALOT of work for shit pay then.. Do they comp the uni cost in lu of lessor pay?
Yes I do alot of work for shit pay in the hope that when I finish uni they will remember all the shit I've done for them and reward me accordingly. I should be able to skip a couple of pay grades because I've started so early.
I haven't had a pay rise since Jan 2008 so I'm f**kin due one. flamin mongrels.
@thristan, i think shan has merged all your old posts into astrothristan2, but it hasn't updated your post count
yeh an i apparently joined a month ago - im such a n00bie-whore :blush:
i asked to have my joined date set at 14th april 2002 (when sau started) but i didnt get a reply
laaaaaaaaaaaaaaame!
we can't all be mega-rice house salesmen :blush:
I haven’t been a sleazy house sales-boy in years! Dabbled in property management and Business Development for the salary security.
I change jobs as often as I change cars haha!! If only you knew what has crossed my mind this time (job wise).
I haven't been a sleazy house sales-boy in years! Dabbled in property management and Business Development for the salary security.
no josh, you're too freaking small to be a porn star
I'm pretty sure you will be and the other advantage is I find Aussies in general value experience and relationship more than anything else. So you'll probably end up being offered a job there (save you the trouble of looking for a job at this kinda economic situation).
They hardly increase vac student's pay anyway or at least I know my company doesnt. When are you graduatiing? My company's looking for grads if you're interested.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
