you kents should be awake working on cars. im starting on mine in 15 lol epic
If I had a car to work on... I would be. Your parents let you do that at their house. My mother would remove my balls.
Tristan, I'll out cook you. :)
I live in The Gap, drive a R33 GT-R. White.
Enjoy the silence.
The Gap? That's pretty hilly... that's a lot of waves for a little boat! Be careful you don't capsize!!
Hahah, tell your mother it’s better than snorting lines.
Hahah, tell your mother it's better than snorting lines.
It doesn't matter what I want to do. I'm still not allowed to. Whether it be lines of cocaine or 'lines of Nissan. The joy of being bankrupt :)
If I wanted to just do an axle swap, or put the car up on jacks and swap all the brakes over, or... whatever! Instant ball removal. Dude.. the stuff I have in MY BEDROOM is considered in the way. Taking up space. etc etc etc. I have about 6 things in my room plus my clothes. It's bullshit.
But hey... free rent while I'm a destitute bastard... *shrug*
lol makes me appreciate how awesome my parents are lol. Do whatever I want lol most of the time Dad wants to help. Offered to get another shed when I said I wanted a track car lol.
I just don't ask :)
Enjoy the silence.
im heading to the gap tonight lol :)
and josh i <3 your piggy lexus
post the pics where you got owned by the speed bump
so car is running like a dream..
cbf putting the oil cooler on.. :)
handles like its on super rails now..
but they f**ked the wheel allignment today
guess time to book it on monday..
:P ill destroy you guido ;)
