i think his just excited about driving my car.. thats all :P
unlike gayskis car no one is claerly excited about it since he has some cupping to do
the more u drag it on the longer the cup will be danskis..
better start clearing your calenda..its gonna be nuts!
I see what you did there :P
Now now roundsuns you know all this negativity isnt good for you blood pressure.
Hey, its Taco! long time no see mate
Unfortunately you won't get to compete against me, they put mexicans in their own class :P
...naah but dirty SR will be in road 6, I am in road 8. Still be fun but :P When you gonna be out?
I know, i been kinda busy with college.. graduating in 3 months.
HAHA yeh we re too good, it'd be an unfair competition!
well, i have ordered some upgrades for my car.. once i get the chance to fit it all and take it for a tune i'll be out and about..
you better start practising eh :D
ARRRR-BEEEEE not a tractor motor
don't worry tas, you'll get to race me in thristan's 32. If you spend as much money on it as you did the S13, you should beat me.
...But I will get to win at least 3 or 4 more years untill yours is ready :P
Edited by Smity42
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
