i sure can! and i can even fit up all the parts you mong!!
go to pceperformance.com.au and contact us and email through the list of what you want!!
colin: RE turbo run in..i have actually done some modification with turbo lines and such so the actual run in process is basically keeping an eye on what ive done before i turn up the boost..i try to do it right first time, everytime!
Tas you sexy beast, can you help out with any of those?
thats now what you told me last night :)
got abit of news on thursday night for you guys with girls in mind
:) trust u to pick the week im not going to be there
hey!
wraith is the shit!
:D I like this guy.
tristan only a couple of weeks till uni hols :D
my last piece is due friday :P:D:D
jizz-tastic
will destory your rolling shell!
man a kid in a wheel chair could destroy a rolling shell. (no ofence intended at the disabled community)
least it has less SR :D
even if it was fully built im sure kids in wheel chairs like this one will still beat you
about the SR? rofl i will make you eat those words when i whip you through the corners!
yell
like that rb powered r32 your getting? least u got the motor right this time :D
ps: did u sort ur shit out with me old man? did he rip shit, and u got stuck listening to it?
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
