i sure can! and i can even fit up all the parts you mong!!
go to pceperformance.com.au and contact us and email through the list of what you want!!
colin: RE turbo run in..i have actually done some modification with turbo lines and such so the actual run in process is basically keeping an eye on what ive done before i turn up the boost..i try to do it right first time, everytime!
Tas you sexy beast, can you help out with any of those?
thats now what you told me last night :)
got abit of news on thursday night for you guys with girls in mind
:) trust u to pick the week im not going to be there
hey!
wraith is the shit!
:D I like this guy.
tristan only a couple of weeks till uni hols :D
my last piece is due friday :P:D:D
jizz-tastic
will destory your rolling shell!
man a kid in a wheel chair could destroy a rolling shell. (no ofence intended at the disabled community)
least it has less SR :D
even if it was fully built im sure kids in wheel chairs like this one will still beat you
about the SR? rofl i will make you eat those words when i whip you through the corners!
yell
like that rb powered r32 your getting? least u got the motor right this time :D
ps: did u sort ur shit out with me old man? did he rip shit, and u got stuck listening to it?
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
