matey as i said before.. slip me some cash and i will do the independant inspection for you.. im sure we can work out something!!
Will do :( - if it's still around, there's a turbo auto s13 in hamilton that looks ok. Hopefully get that and do a manual conversion. If not, I'll try and find a decent s13 that we can throw an RB into. Or who knows? There may be a tidy 180 available, or a 32... time will tell!
Wait till Thursday when youve got 300rwkw of RB muscle under your ass :cool:
Wooooooooo
lol
You BETTER be taking me for a spin when you come to Baskins! I'll even take the risk of losing my seat for that!
you ever... ever.... EVER link me to a Holden again... and I'll link your nuts to extinction buddy boy :yes:
I'm gonna have to bail on tonight also
I'd make the effort if i had a car to drive, but CBF for passenger
*raises pinky*
Colin, dibs on your passenger seat?
btw - need the info for tonight -where am I meeting you guys? should I just meet you at your house tas and ride backseat till we meet up with Colin?
Can only see the glow worms at 3am that's why it's so late. Wouldn't wanna go all the way through springbrook and miss the glow worms :cool:
If you thinking about a good drive down that way, I know a good way. Then morning I passed you on Calagribar road, I was just coming back from an epic drive. PM if you want this information, though I may not give it to you and make you wait until next weekend.
WOW JOHN WTF?!
*shrug* apparently when there's a little green 'woo already on the roundabout, and approaching you... you enter the roundabout... I must have cut class that day in driver's ed...
how are all your injuries going
*cough*compensation*cough*
haha CBF to be honest hey. I taught her how to use a roundabout. she'll never do it again. crazy kiwi's.
oh, her car is two weeks old ROFL!!
tas - you can put a PCE sticker on whatever I buy :D
Geoff - I missed that post before. Good to hear man, congrats!
does anyone know what wheels are on this boat? I like 'em... and want a set. Hektik rims bro!
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
