does anyone know what wheels are on this boat? I like 'em... and want a set. Hektik rims bro!
im glad your always being a funny kent. they look like chromes been canned black.
I am impressed dave. lot of work
do mine when you are finished? :D
if you sign the deed over to me :D i wana build another after this one to. ill buy all the right tools this time :geek:
Will do :D - if it's still around, there's a turbo auto s13 in hamilton that looks ok. Hopefully get that and do a manual conversion. If not, I'll try and find a decent s13 that we can throw an RB into. Or who knows? There may be a tidy 180 available, or a 32... time will tell!
I am about to throw a questionable amount of cash at my car so its running again - Make me a stupid offer.
Sick thread Dave. So much work eh. Rescepta.
Well the 31 is home :D Tried to start it, dead battery so jumped it and drove it up and down the street with half the front end missing lol. Box feels pretty nice and it sounds tough as f**k with the straight pipe & no cat lol.
test fitted the guard i bought off ebay and the front end gear I got off Martin/Dan. Will need a bit of work but it looks good. Pictures tomorrow when its light lol. Can't wait to start now :D Won't get started this weekend though because I need to give the GTR a bit of love haha.
if you need any other parts or panels i got a fair bit of them lying around here at home, also if you need bolts i got them from the 2 31's i have wrecked
Panels i'm all set unless I decide to replace the passenger side rear door which has a bit of a ding in it. I reckon it will come out though. Bolts I definitely need for the front guard and fitting the front bar etc.
Ok i'll round up the bolts to hold that stuff together. I got a rear left hand door if you want it, not sure if its straight or whatever but i'll check it out tomorrow if you want it you can take it
Cheers bud. I'll leave the door for now. I reckon I can get the ding out of this one, its not that bad.
Uni work is gay. Looking forward to springbrook later :D
$6,400? whats the matter with that?
Read the description. Just needs blah blah blah. Just needs to cost 3k less.
You must be joking yeah.
gold! :bunny:
wow ohk i take it back, i didnt realise the thing was f**ked - i thought i was just a 32 gtst with average paint
love the run last night colin cheers for that :)
hope i wasnt too slow :$
roll call for the BBQ tommorrow??
whos inners and whos bringing what!?!?!?
i'm a neg for tmr
too slow? where did you guys head? mtns?
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
