im in my own personal recession -
i need this cheque to hurry the f**k up and go thru so i cant pick up the 180
i think i want 17*9.5 +15 black driftdeks
WTF the bank doing? Talk about efficiency.
yeeh i kno hey
i used the "not acceptable line"
got put thru to 2 different bank managers, and guess waht? my funds have now cleared :cool::)
Edited by astrotristan2
Josh we started a fight club at the car wash but obviously Brandon wasn't listening to the rules. Rule 1: You don't talk about fight club!
DONE! Now stop asking me
Else
WSname = ActiveCell.Value
Set wsheet = Worksheets(WSname)
If wsheet Is Nothing Then
Set TemplateSheet = Worksheets("Template")
TemplateSheet.Copy after:=Sheets(1)
ActiveSheet.Name = WSname
ActiveSheet.Range("C3").Value = WSname
ActiveSheet.Range("C4").Value = ""
Call CopyData
Else
Call CopyData
End If
Anyone can solve this for me?
WSname = ActiveCell.Value ====> this shit works
Set wsheet = Worksheets(WSname) ====> but this doesnt.
Apparently it doesnt work because that sheet doesnt exist. Maybe I can use this error (on error goto) to skip to the next step which I want to do??
I'm trying to check if the sheet exist or not. And ths sheet that I'm check is variable.
I might come, one day. Maybe. Haha
Else
Call CopyData
Else
Call CopyData
End If
x zero.
Brandon, does it not work all the time, or only not work if the sheet doesnt exist?
The on error goto WORKED! That bit on Set wsheet = Worksheets(WSname), only work if the sheet exist. So I dont know how the f**k you're suppose to check a variable sheetname. It'll only work if you wanna check a pre-specified sheetname.
Now I've got another problem of making the sheet active again because of that. This macro shit is fun and time flies when you're troubleshooting
No ice creams from me. Micks' a champ for fixing that Evo up.
Lol lobster back piping ftw?
Bring it on Joshy. No hair pulling or scratchin though :cool:
x zero.
I believe its /zero.
excel macros are sh!t coz they are still based on VB6 which came out about when i was in primary school :S
programming languages have come so far since then but macros are still stuck in the stone ages
to make the sheet active wsheet.activate() or something like that should do it.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
