not going to register my car today..
tomomorrow!!!
going major service and time belt today!!
other deliciuos parts going in tommorrow
Hey Tas did you end up finding out if Federal make a street legal semi slick?
I'd say yes
http://www.skylinesaustralia.com/forums/Fe...es-t271212.html
However, they sorta look more like a uber soft street tire, apposed to like Advan A048's and Toyo R888's etc
I'd say yes
Thanks Josh ;)
Have to try chase tas up and see if he can get these in a 19"
Hmmmm I wonder how much the 265/30ZR19 are
Ring around 5 different shops and get 5 different price's.
My price for 16/205's are anything from around $350 - $400ea
Josh seeing as though your such a fountain of knowledge today . . . IYO whats the best place to get a 3"cat (doesnt matter about highflow as im just gona gut it anyways) and a set of adjustable camber arms for the rear of the 34?
Ahh stuff that I think ill stick wit the federals, they waaaay cheaper :D
PCE!
    • I have been wondering if this is as simple as a voltage issue with the battery. Even on a charger, I can’t seem to get it over 11.8V on the terminals.    Unless the alternator has failed as well, that wouldn’t cause it to die in the middle of driving though.
    • I’ll give this a shot next time I’m able to wrench on it.    I was able to get my hands on a Haltech Nexus, so that should help with some of the more bizarre troubleshooting. Make sure the CAS is actually sending signal and will be able to set the proper dwell on the R35 coils.    I’ve checked power/grounds/signals at the CAS, ignitor, and plugs and it was all there. Granted this was static with ignition on, not cranking.    I also plan on swapping out the fuel filter and throwing on a fuel pressure gauge at the rail just to confirm I’m getting the correct pressure at the rail. 43psi if I recall correctly.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
