try pce? u guys make me laugh just got off the phone with them..
ordered! i was rushing this morning because i wanted to get it registered today.. turns out shit happends as it always does.. has to be delayed again..
oh and dan timing belt, water pump arrived.. the car is already prepared to drop it in. wont take 7 weeks to do a timing belt :P
dont get colin upset his having his rags atm.. dont want to make his ltitle ranga nuts upset ..they might bleed ;)
Was trying to find a decent alloy rad ..that will bolt up to RB20 and 26 with clutch fan/shruod and still have the most cooling effectiveness
sorted!
where / what brand did you go with?
info?
do they make one for 31s?
    • Noice. Congrats on the big day too!   don’t forget to never eat in the Skyline 🤣
    • Overnight parts from Amazon, let's go. Replaced nearly every o-rings, minus 2x from the pumps. Seems the kit is short? Then again when I replaced the main pump a few years back it did come with new seals so we are good. Yiewwww, ready for legal stimulants.
    • I'm only really familiar with the R33 setup, the factory filter is very much an encourage fuel pick up thingo.  The factory pump sits about half way down into the tank and the sock runs down into the bottom of the tank.  Mounting an aftermarket pump in the factory location with the typical tiny Walbro filter, I had huge fuel surge issues once the fuel level dropped below 50%.
    • Hi Gent, Got my r34 GTT 1999 ,wondering if anyone has a stock airbox with snorkel? currenly it has a pod filter which im planning to remove and install the stock part, as this needs to go to vic road for inspection. Appreciate your assistance.
    • Yeah, I still dunno. The size of the sock should only matter if it is blocked. It is, after all, a filter rather than a "thing to encourage fuel pickup". He has modded the original so that it is now down on the floor, so it's not physically the same as in the original complaint, yet does the same thing. I therefore lean to the problem being somewhere else. Sticking some dynomat on there is a worthwhile experiment, but I'd put $10 on it not fixing the problem.
