Say Hi to your mum for me.
and tell her that her bra is in the back of my 180, and ask if she could post my jocks, i think they are still in her room..
Virtual Hi 5!! Is needed.
status on your car bro?
dave explained it to be briefly..
whats the go atm?
Massvie cam lash, which is throwing errors into the ecu and thus turning the car off. When I had the water pump done, the cam belt was done up so tight, I was lucky it didn't snap and throw valves into the motor, so thanks to the muppet who did that, its created the chain of events. It just one of those things that this problem and the fuel pump problem happened at the same time
ugh thats shit mang :P
so now shes at the workshop getting sorted out?
1j it? ;)
Yeap ERD is onto it.
Replacing belt, putting new belt bearing's, replacing temp sensor so the ecu reads right water temp so stop those error's too, CAS might be dicky so bought one from dave as a tester.
Should be back in a week or so running even better than what it did
did you steal time away from my GTR Josh?? cause I would like to drive it again one day :P
haha i told dan to take his time, as it's my only car i wana make sure it wont stop in traffic
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
