Say Hi to your mum for me.
and tell her that her bra is in the back of my 180, and ask if she could post my jocks, i think they are still in her room..
Virtual Hi 5!! Is needed.
status on your car bro?
dave explained it to be briefly..
whats the go atm?
Massvie cam lash, which is throwing errors into the ecu and thus turning the car off. When I had the water pump done, the cam belt was done up so tight, I was lucky it didn't snap and throw valves into the motor, so thanks to the muppet who did that, its created the chain of events. It just one of those things that this problem and the fuel pump problem happened at the same time
ugh thats shit mang :P
so now shes at the workshop getting sorted out?
1j it? ;)
Yeap ERD is onto it.
Replacing belt, putting new belt bearing's, replacing temp sensor so the ecu reads right water temp so stop those error's too, CAS might be dicky so bought one from dave as a tester.
Should be back in a week or so running even better than what it did
did you steal time away from my GTR Josh?? cause I would like to drive it again one day :P
haha i told dan to take his time, as it's my only car i wana make sure it wont stop in traffic
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
