So you're the one trying to get rid of the radiator...
I'm looking at getting the 40mm one from justjap.
hey kev!
matey are you looking into an oil cooler aswell?
son of a bitch
eating contest it is
i agree,
i kept telling him not to mess with the czechs (i think thats where you said you were from) but then he's all "f**k those guys, they think they are sooo good cuz they all do boxing and weightlifting, they aint shit, they aint got shit on me"
i think he has a death wish
I will make that wish come true
on a side note, had a brief moment of panic. downloaded a *cough* unsavory video on the laptop that my other half normally uses, and then couldn't for the fark of me find out where the hell it ended up so I could delete it.
Managed to find it before she had to use it again, but it was touch and go there. She was nearly witness to a sacred union of two men and a donkey.
son of a bitch
KFC at dawn bitch :P
crap thread is crap
Your crap. The thread is crap, the whole damn system is crap!
yo dan,
give me the goss mang,
is the 34 in your garage atm? running and delicious?
Hey bro :P
Yeah man im just about to jump in an go for a drive to the car wash.
Its running like a dream, was gona get bigger rubber for the rear but its hookin up like crazy so dont think ill bother till I get the cooler upgrade and push some more boost in it.
Cant wait for 2moz night its gona be WiCkEd ;)
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
