Nah, Just cant get that song out of my head..
Plus if all else failed i'd still be able to help myself out lol
wow. :P
My webcam is finally working. Telstra pulled their finger out so its all good now. No pan or zoom features though which is disapointing. Apparently its illegal..invasion of privacy and all that jazz. So no perving on balconys from the computer. Will have to do it the old fashioned way with a dumpy level on top of the jump lol
Normally I don't like bodykits on 33s but this one is ok. Really aggressive. The stance pretty good as well.
Plus it is armoured so it can survive trips to the stains, dbay, etc
Edited by Smity42
Thats right, I forgot 31s are the only skylines with decent boot space
Ah so they are good for something :)
:O:P
Smaller bodies. you can fit more of them in that way.
Agreed :) you gotta try steer clear of the big ones, they just to hard to get in the trunk :D
cbf quoting.
Thats a huge boot on that thing, Martin. looks almost like a 31 from that perspective.
And its a very sad state of affairs if you can't even help yourself out. :S
Pity about the pan and zoom Colin. might have been good for watching the A1s - among other things. plenty to look at on the balconies at that time of year :P
thats signature worthy :P
hahaah Nooooooooo :D But it is the Truth lol
See how much fun you are becks? You need to stop dogging us and come to baskins
Im not dogging ya's intentionally. I'll come again.. ;)
Dont all act like you guys are the only ones that have a bit of Solo action.. lol
Edited by 83CKS
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
