yea that was once.. pulled the fuse out and took it drifting..
was happy for a stock outfit with just R34 stock suspension on the front.. lost my radiator, Optima battery drycell, rad shroud that day :P
lol. One of our directors has requested another webcam to be set up with pan/tilt/zoom on it. So I'm getting another toy to play with. If they give me access to it that is. I doubt it. Pricks.
omg it rained for 2mins then starting to sunshine again
Where abouts are you?
Anyone know whats it like on the sth side at all?? :)
Leaving the Valley in about half an hour...
Holy page whores thread man :)
So anways I took my mate for a drive and he said I wont be able to take my car around lakeside because its too loud :P
What tracks dont have noise restrictions?
You're an engineer Colin, build it so you've got access.
Ooh, looks like those storms turn up this arv! :P
I'll get access somehow. I'm the one who's organising it so I figure they'll probably give me the user and password to pass on to the director lol.
So anways I took my mate for a drive and he said I wont be able to take my car around lakeside because its too loud :(
QR has no noise restrictions I'm fairly sure.
tracks with no noise restrictions..
QR.. and other states i believe..
lakeside is only like that because of residential areas some what close by
Cool thanks :(
Hell YES!! R34 All the way... :P
yeah lakeside mainly coz of one whinging f**k neighbour. But your allowed 95dB, you'd be surprised how loud that is. You might be OK.
QR is fine.
@Becks, its going to be mighty messy leaving the valley at 4ish :S. Thats about spot on when the main storm is meant to hit
I beat the storm home ;) Gotta get to cricket somehow later tonight but :(.
Advantage of driving home at 3pm in the rain to beat the storm: Schoolgirls. Of the soaking wet variety. :P:)
QR is fine.
I beat the storm home ;) Gotta get to cricket somehow later tonight but :( .
OH NO, Well i'm off to try and get my baby home safe and sound.. ;)
Have a good night everyone!
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
