300k for that wow... new farm must be really moving up..
i was there recently for business man i must say its really moving up in the market.. besides all the whores and what not..
sounds like danski wuold move there.. he loves 1 dorra ho's
Martin, pretty sure I saw you zooming around the indro bowls club earlier tonight. I was once again in the beast*
*1999 ford festiva, 1.3l, automatic
Hows the 180 goin Tris?
shes going alright matey - currently off the road awaiting her braking upgrade - "overnight parts from japan" lolz
tigs?
WHO WHAT WHEN WHERE?!
Thats one thing I WOULD put back into my car.. Air Con.
too much weight!
haha im currently cruising in my brothers '99 auto festiva hahaha
too much weight!
I considered chasing after him and racing him, but nobody wants to be beaten by a car shaped like a pokemon ball
driven by an ape....
dba's - slotted on front, new blanks on rear, and new ebc pads
its not a time-attack set up - just something nice and reasonably priced hahaha (i saw project MU set ups worth over 4k! - for the fronts!)
hey colin you need any other random 31 parts. i'll be throwing out a heap of stuff this weekend, so if you need anything let me know i'll see if i got it.
Full set of standard doors here, blue with tinted windows. I just need to fit the power windows to it first
I'm finishing off a bottle of bourbon by drinking from the bottle
Does it have a little umbrella in the bottle ? That would make it super classy.
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
