So whats everyone up to tonight??
race f**king mustangs?
probs to a fully rad nebo run, followed up by a huge bake and skids in yatla/stapyton, followed up by highspeed highway run, a POWERSHIFT, then going to drive thru the valley, rev teh shit outa my vtec at everyone that rocks up next to me, maybe go to milton macas and start up my subs and pop my bonnet, then finish up at asply hyperdome
WHAT A NIGHT PLANNED AHEAD
time to make ur appearance now!! :D
i dont know a new member just reading having fun... touchin bits?
his hands were busy, they are free now - and i feel like a smoke and rolling over and going to sleep
Don't forget to stop by 'that workshop' and drop 2nd in their carpark
Sounds Fulli Hecktic
NFI eh. Maybe his tractor got stuck in a field somewhere? Alright nigs I gotta stop wasting time now. Back into work lol. Laters
yeh probs about time i get ready for uni
holla bishes
the lack of tractor love around here hurts my feelings, I love working on Annas car, for a home mechanic rb26dett fails badly in comparison...actually for street driving it does too, feeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeel the lag
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
