i dont have it as a url :whistling: its only saved here locally, and i cant see the upload button :thumbsup: lol
oh wait i played around and found a way! woot
dam straight and remembre its not gay if it doesnt cross swords! :whistling:
i only had RS*R on mine atm.. but with the new transplant.. its gonna get all sexy time parts on it..
every time i think about what part i want to install first.. i just want to roll over and sleep alraedy had my fill LOL
and yes guys... the neons are staying :thumbsup:
Edited by Redsuns88
i dont like poolished up engine bays..
i rather play the game of hide and seek :whistling: with trying to retain the factory look :thumbsup:
works well with tristans 180
sshhh dont tell ne one,
its a t25 with a fmic and a catback zorts
    • Don't assume too much when there is a voltage issue....if the battery is flat and the alternator not charging it is easy for the voltage to drop way low at the ECU due to the draw of stuff like coils, fuel pump etc Whatever you see at the battery with the motor off, it should be at least 13.8 with it running
    • I have been wondering if this is as simple as a voltage issue with the battery. Even on a charger, I can’t seem to get it over 11.8V on the terminals.    Unless the alternator has failed as well, that wouldn’t cause it to die in the middle of driving though.
    • I’ll give this a shot next time I’m able to wrench on it.    I was able to get my hands on a Haltech Nexus, so that should help with some of the more bizarre troubleshooting. Make sure the CAS is actually sending signal and will be able to set the proper dwell on the R35 coils.    I’ve checked power/grounds/signals at the CAS, ignitor, and plugs and it was all there. Granted this was static with ignition on, not cranking.    I also plan on swapping out the fuel filter and throwing on a fuel pressure gauge at the rail just to confirm I’m getting the correct pressure at the rail. 43psi if I recall correctly.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
