Kaizen Garage
New and Used Parts as well as Specialised Electrical Work for Toyota, Nissan, Mazda and Subaru
QLD Agent for Adaptronic Engine Management
Phone Anthony 0415 185 815 [email protected]
i dont think u understand my history with efi
they didnt take my 32 on the dyno at their dyno day - and because myself and some of the others chucked a stink on the forums said it really wasnt good enough blah blah blah,
they havnt really liked myself, or some of the others :ninja:
oh i see
*serious face* buy an adaptronic they have ignition cut launch control
yeeeh - one day ill explain the long version to you hahaha
ill hav a read on the adaptronic - i must admit though i do like the fact that the pfc is so common in srs :ninja:
its common because it is old, adaptronic is the new black, pretty much every sr in the drift scene is using them now...and the software is so easy anyone could use it and it takes 4 seconds to download off the site
wow andy thats pretty sick how the ecu can change itself when it senses more modifications..
yes pretty cool feature that, we need to get outs up and running
ps Andy here CBF signing in
hey colin we should do a midnight mountain run in our project 31's i got no headlights or interior and im running space savers!
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
